Ok, after reading lots on this site, I have most of my plan on how to upgrade a totally stock GN suspension w/110k miles. I want to handle as well as possible, hook up better (but I doubt I'll be on the track), and be a relatively comfortable daily driver. I toyed w/Kirban's GNX suspension, but thinking of the following--similar to our moderator:
All body braces for GNX, new poly body bushings plus missing GNX, Bilsteins all around, GW rear LCAs, either edlebrock or currie adj UCAs (spherical bearings and 1LE rubber), and the HNR rear bar. For the front, SCC UCAs w/Howe ball joint, stock LCAs w/del-alum bushings. Not sure which front sway bar would go well w/my goals and the rear hnr bar, thinking the 36MM hollow camaro. I plan on going w/GTA 16in wheels all around.
For the brakes, I will change over to the hydroboost; not sure what would be best front brake w/the SCC UCAs.
I know the HNR bar is really more for the racers hooking up, but i'm sold by everyone that has it absolutely raving over it.
So what would you change given my goals?
Thx!
Thx!
