Nice car here is a discription
1986 Monte Carlo SS guaranteed to be the cleanest, most well maintained SS in the country! Only 33000 original miles.
I have owned this car for 19 years. This car has never seen rain, or been left in the sun for more then one day at a time.
The interior in totally stock except for the custom head rests. There are no cracks or sun fade anywhere. The outside is original paint except for wheel wells (the car came with mud flaps which I removed and then painted the inner lip.) The rims are perfect, no cracks or marks, and the weights have been installed on the inside only. The windows are tinted aftermarket. There are a few stone chips (not many as the car has a bra for any highway cruises) the inside of the trunk is all original with a custom seat brace kit from Kirbans.
The undercarriage is perfect, not a spot missed. I took the suspension, gas tank, and power train out and polished the entire undercarriage. Any bolt that was dirty was replaced with oem or better quality. I used grade 8 bolts on the suspension and stainless nylock nuts instead of lockwashers. All suspension bushings were replaced with eurothane as were the motor mounts. The rear end and all frame braces were painted. The frame was left with factory wax type paint to keep original. The rear diff is out of a Grand National, it is an 8.5, 3.42 posi... Also, the 3.42 ratio gets 21 mpg on the highway. I also put new AC Delco shocks in at this time. The drive shaft is a 3inch .085 wall steel with spicer U joints. A custom drive shaft hoop was made to keep it looking factory.
The tranny is a stock 200 r4 with a transgo shift kit and all the usual upgrades to make it more it more durable like a GN servo, hardened stator support and a TCI lockup torque converter. It shifts stock under normal driving and firm under hard acceleration. There is also a tranny cooler with braided steel lines and aluminum Russle fittings.
The engine is a 9.5 to 1, 355 four bolt block with all the good pieces, including forged pistons, hydraulic cam, roller rockers, vortec steel heads and a Z28 oil pan. The headers are alum coated and go to cut outs into a stock mandrel bent dynamax exaust. The intake is a rpm air gap from Edlebrock. The carb is a Q-jet built by a super stock specialalist. The distributor is an hei withan msd coil and msd box hidden under the dash. The water pump is aluminum from Edlebrock with aluminum black powder coated March pulleys. All fuel and tranny lines are high pressure braided stainless with aluminum fittings. This car made 351 hp at the rear wheels, dyno sheets available. I also have the stock block and heads and they ( with a few other parts), also go with the car. There is an electric fan and fuel pump and if the new owner wants more stock look, I will install a new clutch fan and mechanical fuel pump. The wiper motor, alternator, master cylinder were also soda blasted and clear coated to keep looking clean forever.
This car rides and handles better then new. It has never been smoked in. It is a comfortable ride, firm but not harsh. The car idles smooth in gear with only slight lope in the cam shaft. The power brakes and all other accessories work as stock..
NO STROKERS, JOKERS, MEN THAT HAE TO ASK THEIR WIVES OR PEOPLE ON MEDICATION NEED PHONE
Good luck on selling or trading it for a GN.
