batmansbuick
Superhero
- May 26, 2001
way, way off topic but I know there is a Turbo Regal / Washing machine master tech out there.
Okay, you know where the water drains out of the discharge hose to a pipe leading outside. Every time it drains, water and soap foam out of the pipe and on to the floor for a few seconds then the remaining water correctly discharges outside.
I've checked to make sure the PVC discharge tube leading outside is clear, and I bought a new discharge hose.
From what I've found on the web, the height of the drain tube is important in relation to atmospheric pressure
any suggestions would help dry up my utility room.
