Wastegate Actuator Bracket
bigballsbilly
Installing a TE series turbo and I'm just now discovered the stock wastegate actuator bracket won't work. I've done some searching and can't find anyone that sells one, so I'll make something that will work.
What have you guys done to overcome this problem?
Drill and tap the lower clamp and use a set screw. Drill a hole through the actuator bracket that's lined up with the set screw. Bolt it on.
Thanks Bison, you'd be the one that would know :) This is how you usually do it?
I'll give it a shot.
I welded a washer to it that would allow it to reach the next hole.
