Wastegate and boost control selection
John Craig (limit engineering) t-66's in 60 housings.
Yea the extra turbo was thrown in cause i was the millionth customer
What is a 60 housing?
What size inlet are on those units?
Quite spiffy looking, would you care to share the specs, or are they top secret :p
Specs nothing special really
Inlet of turbos 3", Have been machined to that large internally Pic of the machined inlet outlets 2.25" The turbos were used cause of a space constraint issue we used to have now i wish i would have gotten big housings. Basically what John told me is they took smaller t04 housings and made them hold a 66 mm setup.
66's next to a set of 44's
Specs for the system are pretty simple
twin t-66's (p trim)
twin 2-230 air-water intercoolers mounted on oposing sides
Innovative pro gates
innovative boost controller
383 ci lt1 motor (normal forged internals hard blocked etc..)
9.5-1 afr 220 heads that have been worked over
rest of car is just normal race fair th400, f*rd nine inch rear with 40 spline axles, aerospace brakes etc... Normal stuff.
If you need anything else on the car just yell
