87Limitedwo2
- Mar 25, 2010
I am in the beginning of sorting some things out on the 87 GN I bought. Has some very nice things done but I don't understand some of what was done. I have owned and built several of these cars mostly to factory spec with bolt-ons. This car has the waste-gage solenoid sitting on the intake manifold on the left side with no vacuum hose hooked to it only the factory wiring plug. The turbo and wastegate are plugged in together with the same vacuum hose.
Can someone clear this up for me: why eliminate the solenoid? and what does it accomplish by putting the hose on the wastegate and turbo? Any info here would be good.
Also, the EGR valve is there but no solenoid or vacuum hoses. I want it to look more original and plan to put the EGR stuff back on. Should I plug the vacuum lines so the EGR cannot work or is this not an issue?
Thanks in advance for any help,
Justin
Justin
