If it was the heat of a WOT pass causing it to stick it would be in the open position.
in your case use a "P" drill on the bushing and leave some end clearance and you should be fine.
Stainless is very malleable so it is very easy to make it out of round. the last DP i made i made the bushing go out of round installing it with a rubber dead blow and had to ream it.
if it is the carbon build up that is causing the shaft to bind one thing that can be done is to take a cut off wheel and make a small groove in the shaft. this also helps in the cleaning between the shaft and the bushing. every time it opens soot will collect in the groove and then be blown out by the pressure in the exhaust. it is not enough leak to notice but does in extreme cases help in cleaning.
Although not the case here, we have seen where the puck does get cocked inside the hole and causes it to not close. To make sure this does not happen always leave 1/8" sealing surface on the short swing side of the WG puck so the puck will hit the face of the turbine housing and slide up so the whole puck can seal. I hope i described this ok.
oh, one more thing i just thought of. once in a while the puck arm to shaft weld will taper onto the shaft. make sure when you pull the puck toward the bushing it swings as freely as it does when not against the face of the bushing.
