If you are talking about the solenoid that bolts to the passenger side valve cover, there's only 2 outlets on it both at the front, one of them the vac tube to the wastegate connects to, and the other should just be a foam filter element or it has fallen off which is no big deal. The tubes should point to the front of the car and the filter element should be on the tube that is closest to the passenger side fender.
There is no top and bottom vac lines off of the solenoid.
Now if you're talking about the vac line itself that has the 'Y' split fitting, the "straight" side goes to the the turbo, on the intake side housing, and the part that branches off goes to the wastegate. and the other end of the straight side goes to the solenoid on the valve cover.
