I dont run a wastegate solinoid do i still need the y between the wastegate and the compresor housing? Rite now just have the hose too solinoid plugged
If you don't want to run a wategate solinoid remove the Y hoses and run a hose from turbo to a manual boost controller than to wastegate if you run just a hose with nothing between what is controlling the boost? A RJC manual controller is a good valve I have one on mine and works well.
Running the hose from the compressor to the wastegate "tuner style" will usually give you lower boost, about 13 lbs.- unless you run a hd wastegate, then you will usually see about 17 #
FWIW Mine had the hose ran from the compressor to the waste gate and the actuator was I'm pretty sure a stocker that someone threaded the end of the actuator rod...I was able to turn the boost up to about 22 or so. Then eventually I snipped the line in half, and added a manual RJC valve and backed down the wastegate and used the vale to reset the boost.
