Wastegate solinoid ?
OTHRWMN
Detroit Lions Fan!!!
I had a hks boost controller on my T. I am taking it out but forgot what vac lines went where. Any help would be great!!
The hks uses 3 vac sources. one goes to the outlet side of the turbo, one goes to the wastegate actuator & the last goes to the line that goes to the factory boost gauge. I am taking the hks out because it only works once in a great while.
Hope this aligns correctly (disregard the dots... it didn't align correctly).
Solenoid
[XXXXXX]............Tee
[XXXXXX]-----\\\\\\\\\\------ to turbo
...............................\\---------to wastegate actuator
HTH
So it just gets T'd from the right side port of the solinoid to the wastegate & turbo.
Thanks!!!!
Not "T'd" .. You have to use the "Y" that's designed to apply the right vacuum/boost signal.
