T- Type Tim
Vice Chairman
- Jul 8, 2001
I have a TIAL 38mm waste gate that i had previously controlled with a bleeder valve set up "tuner style". Iwould push about 26 psi on a safe tune with that setup.
Recently I went to a Ball and spring type controller vs the bleeder style. Preliminary testing was very good with a harder boost hit. Once i started easing the boost up from 15ish #s , I found the limit of the new controller @23psi.
This got me wondering what spring i have in my wastegate since ive had it for several years hooked up tuner style it really wasnt a big deal.
So this morning I take it apart and find I have the yellow spring in it rated for about 10 psi:
I have a large blue and small blue on the way today which according to the chart should put me close to 23psi base boost.
I also ordered a stiffer spring for the controller itself im ready to install. Im not sure if it came with the light or heavy spring , so i will eliminate that variable.
Heavy controller spring:
I wont be able to test for a couple days, but this should put me in a better adjustment range for my application.
Will report on findings soon
