Jonasterg
- May 25, 2001
My dashboard's water temp warning light started flickering recently. It happened after I did some work under the dash (changed my brakes to hydroboost) and pulled some connections loose in the process (symptom was some weird Scanmaster readings).
I spent some time under the dash this weekend trying to chase down all the loose connections and I did find a few. I re-seated the connections and now my Scanmaster readings all look great, but I noticed after cruising around that the water temp idiot light will flicker sometimes.
The engine isn't overheating as far as I can tell. My water temp gage shows roughly 165* and the Scanmaster reads 162-164. Seems like I've got another loose connection but I can't figure out where it's coming from.
Any ideas are appreciated.
