Wave washer in RJC cam sensor repair kit?
josh young
Just wanting to make sure which side the wave washer goes on with the kit, it don't show a picture of the washer itself in the kit. Thanks.
There is no wave washer in the cam sensor repair kit. It is only to repair the broken tab for the interrupter wheel / ring in an emergency so as not to leave you broke down on the road, these parts located under the cam sensor cap. The kit isn't designed or meant for rebuilding the cam sensor.
The kit includes Detailed instructions, Grade 8 Socket head Cap Screw, Lock Washer, and the Stainless Steel Interrupter Trigger Tab.
If you are needing to have the cam sensor rebuilt. You and all of us here are in luck because the service is available and at a price thats hard to beat compared to buying a new one or locating and buying the parts to do it yourself.
Here is a link for the service and what they do when rebuilding it.
http://www.turbobuick.com/threads/cam-sensor-rebuild-service.384393/#post-3090506
gns does noting to prevent the the little tab on the reluctor from braking and spinning loose .. found that out last week after a no start
the rjc fix kit addresses that weak tab part of the disc
now if gns would add the rjc fix to their rebuild that would be great
