You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Anyone know the gm part number for the weather stripping around the driver and passenger window?
outerdoor sealing strips: RH-20674282, + LH-20674283, these are the black ones for GN's only
inner door sealing strips: RH-20363106, + LH-20363107
Upper Roof rails: RH-20737658, + LH-20737659
HTH's
HTH's
Is the seal that is highlighted in my pic the upper roof rail seal?
YES, That's it!
Rock on. Thanks
