Intercooler
- May 24, 2001
I took the weights of the stock bumpers I just pulled off my car that have aluminum bumper inserts and the absorbers attached just like it would be on the car. Weights:
Front= 45 lbs.
Rear= 50 lbs.
Next is the weight of the Kirban front and rear fiberglass bumpers I just got with South East Turbo aluminum mounting brackets. Weights:
Front= 12 lbs. (2 lbs. for the brackets)
Rear= 9 lbs. (2 lbs. for the brackets)
So,
90 lbs. stock front and rear with aluminum inserts and factory brackets/shock absorbers
21 lbs. fiberglass bumpers with aluminum mounting brackets
69 lbs. total weight saved. These numbers would have been higher with stock bumpers and steel inserts.
Front= 45 lbs.
Rear= 50 lbs.
So,
