Weight of Chrome bumpers?
  • Thread starter Thread starter GRAYGHOST
  • Start date Start date
G
GRAYGHOST
Guest
Did not weigh before I sent them down the road, does anybody have an idea of how much they weighed with aluminum supports in them? Front and rear......
I know the bumpers going on now are 6.5 pounds each:eek:
Hope I don't take a hit from either end, it'd be messy!!:eek: :eek:
REAR BUMPER WITH STEEL 69.5
REAR BUMPER WITH ALUMINUM 48
FRONT BUMPER WITH STEEL 64.5
FRONT BUMPER WITH EXPORT BRACE 26.5
FRONT BUMPER WIHTH EXPORT BRACE AND IMPACT SHOCKS THAT CONNECT TO THE FRAME 33.5
the FRONT aluminum support weighs 12
the REAR aluminum support weighs 13
i was able to get that 48 lbs down to LESS than 30lbs, i think its 26 rear and 24 front by cutting the center section out of the impact bar so there was only the ends that held the bumper to the impact shocks.
no straight up and down bumperettes, still has black strip across the length of the bumper-
those are the numbers i got when using my digital bathroom scale, seems to be kinda accurate, measures within 1/2 lb
HTH
BW
Think so....what is the export brace for the front? Is that the same as an aluminum support? Looks like I need to add the 26.5 front bumper to the 12 pound front aluminum support....right?
If that is the case I'm dropping 70 pounds!
