Thanks i will check the weight this weekend and see how they compare. The dioamond pistons look pretty tuff but the top ring is pretty close to the top.
Just for another comparison I run venolias in a bore of 4.055 and the slugs weigh in @ 433 grams. They do gain a little weight because we went with the pin butttons. All in all a pretty light set up.
jay
The longer the rod the shorter the compression distance.The shorter the compression distance the shorter the piston itself which equals a lighter piston.So rod length and stroke greatly effects piston weight.If your comparing weight you may want to also know compression distance.
Piston pins differ in weight as well.A tapered wall pin would weigh less than a solid wall pin.
Sometimes things aren't apples to apples
