Blown&Injected
- May 31, 2001
Well the rebuild seemed good but after some miles I have noticed some problems.
Reverse works fine cold but slips after warm up.
AND
Warm and cold the car often will not start in first if I take off slow. If I give it some gas it will pop into first.
The part throttle shifts seem to be a bit delayed and very hard - especially the 1-2 shift.
AND
If I put the shifter in 1, the trans seems to lock up a bit like it is in forward and reverse - and I don't have a brake.
My thoughts are band too tight and or the shim that the VB kit had me put in front of the TV plunger spring has caused the TV to be to deep in the bore.
What do you guys think? (No pressure readings right now.)
TIA,
AND
AND
TIA,
