Weird howling from power steering pump
coolguywalt
For some reason, being up here in the cold of Colorado, when I start up the GN, the PS pump makes a weird howling sound. It gets louder when the wheel is turned or when the brakes are applied. I have the Hydro-Boost system on my GN, and I am wondering if the Hydro-Boost is giving out. It dosen't leak any PS fluid, and it does it intermittently. Anyone else have the same problem?
Allright, here is the scoop on the PS problem....Hole in a hose, I think. PS fluid resevoir pretty much dry, PS fluid all down the driver's A-Arm and master cylinder and the wheel well...cruddy old lines covered in grease and crap. Sounds simple enough. Now, who here has changed the PS lines on their Hydro-Boost system. I finally found all of the hoses, all special order. I am changing all the lines, might as well. Any suggestions, hints?
Oh, well Autozone had them. Well, at least they had the pressure ones, gear box to Hydroboost and the hydrpboost to pump. The return line I had ordered through Pep Boys, custom fit one, not just 3/8" hose. I will tell you how they all fit together...
