Royal-T-Ltd
- Jul 12, 2003
Okay..... [bkgrd info] i have been fighting an odd drivability problem for the last couple of weeks... the car started randomly shutting down when warm. Block Learn is pegged at 160... i have since checked ALL vacuum lines, replaced an old PCV valve and sprayed Throttle Body cleaner on all lines and Intake. I have reset the IAC, verified all other numbers are within spec, reseated all connections to the ECM/PROM. I have managed to get idle down within spec but randomly when driving i can watch the 02s on the scanmaster and for long periods of time they will read 000.000 and then the BLM is 160 and wideband drops way fat, it drops to 10.0 which is the minimum, so its probably even richer..... i have also replaced the O2 as insurance that it is working properly. CrossCounts are good. Until i saw the O2 numbers were wacky i was gonna throw on another MAF just to see if it made a difference - now i am all confused after seeing the 000s.
My car is a chip car with a Gen2 translator and a 3.5" Aluminum LS1 MAF..... what am i missing.... Until now my T-type has been trouble free and i wouldn't hesitate to drive cross country.... now i can't drive to work.... i am getting depressed and missing all the good cool weather....
so in conclusion, Help a Brother Out
aaron
aaron
