8
86HybridGN
Guest
Have a question about WOT shifting, under normal throttle it shifts ok, but when I floor it, it gets close to the shift point and then feels like the tranny either slips or disappears for a second or 2 (engine rpm's jump) and then it shifts ok, does it from 1-2 and 2-3, only happens under WOT. Had to remove the stock dipstick and put in a Lokar flexible for the 2004R (as they called it) and have it filled right to the line when hot. Does this sound like a low fluid problem (will it hurt it if I add half a quart at a time to test it) or could it be a mechanical problem. Thanks for any help.
