Weldon 1100-a fuel pump
You make no mention as to what the application is, but this would turn me off, if the car is a streeter..
"Compatible with Gasoline Only (not compatible with alcohol / ethanol based fuels)"
Weldon 1100a fuel pump
We use the very same pump. We record fuel pressure and based on the data logs, it has no problem keeping up.
It's a lot quieter and 1/2 the price of some of the other Weldon pumps. For our purpose, it was a no brainer.
great,when you saw we,do you mean tsm and tso cars.Are you using this pump in your tsm car?Im not in a tso/tsm class but it will be a mid 9 second car.I do see it says not for alcohol/meth but i dont plan on running that.It is going to be on the street.Thanks
Whatever he is doing on the TSM car, it's working
Ive spoken to Jim Craig @ Weldon about this pump. Everything he told me will support a very stout 600+ hp motor. Its very quiet in comparison to boot. If anyone has ever spoke to him he will tell you the absolute truth about his products.
As far as I know, I'm the only one using this pump in TSM. When I said, "we", I was referring to the people that help me work on the car.
I e-mailed Jim Craig when I was looking for a pump. According to him, "the 1100-A has the very same flow characteristics as the 2015, if not a tad better." That was based on the fuel pressure I told him I needed to be at, < 80 psi at the regulator. He said the 2015 is a better pump when "extreme" pressures are needed. I do not know what he considers to be "extreme".
Jim told me that the biggest downside to this pump is it is not as easy to rebuild as the 2015.
