I bought a 89tta back in June with intentions of restoring/making a nice driver. when i bought the car the guys i bought it off were idiots, they said the melted a hole in one of the pistons, so they replaced 1 piston and both head gaskets, after seeing some of the work that was done on the car, They are hacks and i was weary, however the car made the 2 hour drive home. Well i didn't drive it much due to a bad turbo, engine oil leaks, 2 bad coils, junk plugs, etc. etc. , and i drive my other car as well(97 supra turbo) so this was just going to sit til winter, and i can tear it apart. well winter is here, i pulled the engine out and started pulling it apart today, the engine ran good,good oil psi, etc so i wasn't going to pull the heads off of it, just reseal everything else and upgrade the injectors, turbo etc. when i pulled the valve covers off, i noticed i have 3 bent push rods, so now im going to pull it all apart, what do you think i should do as far as a rebuild, im not looking for anything crazy, as i have my other car as well, but i have a pt52 turbo, 50lb inj and a chip for now that is going on the car. what are your guys opinions on what i should do, i know its hard to say without seeing everything but... any ideas would be helpful, again I don't need anything to handle crazy power, something in the 11s would be good. and im trying to not spend a ton of cash in this build either.
