Hello all, after a lot of deliberation, its time to part ways with my GN,
Second owner-owned for about 10-12 years
All original w/bolt on's
145,000 KM's
Typical 87 GM paint-original 6-7 out of 10
Interior is a 8-9 out of 10
Never been hit
Have all original parts that were taken off the car.
Original engine (not a oil burner) never been out, apart or opened.
Original Transmision- shifts firm
I will try and remeber every bolt on i have and all the bits i have collected over the years:
ATR LC intercooler (w/trunk set up-not installed)
SMC alky
Direct scan
TE45A turbo
3500 9" billet lock up (Have original in a box)
Max Effort 16 pos and assorted chips
THDP
55lb injectors
EGT Guage
Hi/low fan switch
Billet LCA's
Bcst boost controller
Fan hi/low switch
Audible knock modual
NIB comp cams cam kit 212/212
Comp cams Billet roller cam .511/.519(Used but fresh, in a box)
set of roller lifters (Used but fresh, in a box)
set of NIB TRW forged pistons (plus three extra's)
Set of NIB TRW file fit rings
TRW NIB main/rod bearings
Billet center caps NIB
Fresh Champion GN1's w/1.65 roller rockers (Springs installed for billet roller-In a box)
NIB ARP hardware-Head/main studs-(con rod bolts also-i think )
Spare 10/10 turbo crank shaft (freshly ground)
Spare AC Delco Rebuilt Long block w/turbo crank and 8445 heads (10/10 crank 30 over bore)
Spare AC Delco Rebuilt BFR transmision (with a converter i think,have not opened the crate in years..)
NIB Ac Delco power master
2-Air bags
Line lock set up -not installed
ATR double fuel pumps -not installed with new pumps
Polished/Ported upper plenum (original plenum w/TB is in a box)
Ac Delco CD player (Original radio in a box)
8 1/2 x15 polished auto drags w/MT slicks almost new 10 passes?
30lb bottle of the good stuff to keep you cool
new GM rad (no issues with the original its in a box)
Drive shaft loop
spare coil packs/moduals/cam sensors/tps/iac wire sets (original wires in a box)
I would have to go through all my stuff, i am sure there's more i am not thinking of.....
I will snap some pic's for anyone that is interested
16,000 CAD (about 14,500 usd) priced for a quick sale (before i change my mind)
James
780-440-1515
145,000 KM's
Never been hit
SMC alky
Direct scan
TE45A turbo
THDP
55lb injectors
EGT Guage
Hi/low fan switch
Billet LCA's
Fan hi/low switch
2-Air bags
Drive shaft loop
James
780-440-1515
