wh1 ?
jopaustu
I have a 1986 t type. Recently I was going over the options (trunk) and the rpo (door). The door sticker says Wh1, but I was under the impression that these were two tone paint schemes. My car is black and very low optioned. I believe everything is original (paint, interior,drivetrain). I have owned this car for 2 years,but was in the family since 1993. Any enlightenment would be appreciated. Love this car.. Joe
I believe your car was painted Prior because it will be 2 tone for a wh-1.
I believe you are correct. The d86 code (2 tone) is on the sticker, as well as the other options listed on the Wh1 registry. I am glad I did not have the car repainted last spring(black) . Car will be returned to its original paint scheme. Are these wh1 cars rare? I also have a digital cluster and wonderif anyone knows the option code for this???? :-)
Yes, that's where I found the option codes for the Wh1. I think I will join the registry. This car is nearly "bare bones" ,but has alluminum bumper supports, aluminum drums, non posi,no power anything. Stil running R 12 in ac system.. but why the digital dash.. make no sense. That's why I am curious about the cluster option.. would lik to find out if my equipment is factory or after (like paint job)
Should the WH1 code be on the trunk options(sticker)or just on the other one I believe was once on the door?(in glove box now). What's the difference in the 2 ? I mean they are not identical. I believe both have the vin on them
Because back then, there was only a few packages and - you could order it like going to Waffle House..anyway you wanted to.
U52 was just another option.
You could have a limited with roll up windows I believe. Perhaps not, but almost.
