I have been told if it ends with 144 it is a H.D. but that does not mean it is for a ta or a te, however the ta can be modified for the te style turbo. I have both a standard which does not end in 144 and a H.D. that does, and when you pull on each ones rod there is a big difference. The rod is much harder to move with the H.D. actuator. I do not know what sounds worse pulling or yanking the rod, or for some which sounds better.
I have an actuator that reads the following and was told it is HD? any info is appreciated. thnx.
430819-39
05269
25197
....the rod takes some to pull.
430819-39
05269
25197
