firm believer of verifying what you have, just like you're doing....this project is an investment of time and dollars...if this forum can share tips so that you can do something once and move on without wasting $$$ on parts that don't work well together since this is your FIRST turbo buick, that is a winner. can't build a turbo buick motor like a small block chevy - the specs and tolerances are vastly different.
on the cam, while any lobe can abnormally wear, it is usually the #3 exhaust lobe that becomes problematic first. It's inherent in all the TB production blocks - the geometry of the casting for that lifter bore. On the Stage I and II blocks we would bore the lifter holes and use bronze inserts for all. but no one would do that work on the 109 blocks. just something to be aware of as you inspect and verify.
since it is the holiday season and jegs and summit are plastering my inbox with discount codes (why the suggestion to create accounts there) and Kirban's has published his Christmas specials - just things to know...
when you get to the radiator...
if it is the original stock radiator, it can be re-cored. any competent local rad shop will do. 2 choices for replacement core:
1. a 3-row core, 2" thick, using 1/2" tubes is about $540 reusing your original end tanks. like OEM, will fit fine OR
2. a 3-row core, 2-1/4" thick, using 5/8" tubes is about $600 reusing the original end tanks.
the problem with the 2-1/4" thick radiator is fitment under the stock rad top plate and stock rubber cushions. probably need the larger cushions and may have to trim the radiator core support tab like what needs to be done when using the aftermarket aluminum radiators. See coldcase on jegs for pic of trimming rad support.
https://www.jegs.com/i/Cold-Case-Radiators/359/GMB57A/10002/-1
https://www.summitracing.com/parts/rad-gmb57a
The coldcase radiator is a really nice unit. it's more cooling capacity than what a stocker needs but is cheaper than re-coring an original. Depends what you want for the car. Some are flat out against modifying the tab on the rad support to make the coldcase fit. Jegs and summit holiday codes have already been for another $25 off a $250 purchase and free shipping. If you can wait til Spring, Kirban's does a nice discount on the ColdCase radiators in April. hopefully he will offer it again in 2019.
some have used the Alradco aluminum replacement radiator and have high praise for it. lots of threads discussing replacement rads.
here is one when Kirban's introduced the ColdCase last year. I posted close up pics of the coldcase.
https://turbobuick.com/threads/replacement-radiator-suggestions.450029/
here is the thread introducing the alradco.
https://turbobuick.com/threads/aluminum-radiator-american-made-by-alradco.341844/
