Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
You are welcome. Wait 'til the girls reach driving age and they insist, "Dad, take me driving - IN THE BUICK!"
Those woodgrain Limited dash plaque and bezels don't really come up a lot as I've seen - especially as a set. Yours has the grey tones and they look really good. glad to see the dash is not all hacked up and that there are no gauges mounted in the dash plaque like in the '90s.
Good progress on the RPO codes. I figure you've found the RPO code help on gnttype.org. Attached below are PDF's to complete your work. Note that the GM Master list from Nov 2002 has omitted some codes from the '80s that are no longer active/applicable and has re-assigned other codes. My GN decoding is complete and the F-body forum sourced document is period correct.
recover the steering wheel:
the solution is in this thread: https://turbobuick.com/threads/recovered-steering-wheels.459218/
Wastegate solenoid:
yours is missing. with a TT chip, ECM is controlling/bleeding excess boost pressure via that solenoid. check out these two threads below...
https://turbobuick.com/threads/boost-solenoid.460359/
https://turbobuick.com/threads/stock-wastegate-solenoid-valve-available-aftermarket.450728/
the second thread got hijacked after I did the informational write-up whereas it turned into a diagnostic session by another member.
Bottom line is that you can use either the factory 84-85 wastegate solenoid or the 86-87/89 TTA wastegate solenoid. don't get suckered into buying NOS 86-87/89 TTA solenoids for hundreds of dollars. there are plenty of good used ones around and there are some NOS 84-85 solenoids around. just ask.
Brakes:
when you get to overhauling the brake system, you'll want one of those brass proportioning valves. If replacing the brake lines, Classic tube gets my vote - OE or Stainless. If replacing the 3 flex hoses (front wheels & above differential) OE AC Delco or Raybestos via RockAuto or Amazon works. If choosing the braided flex lines, just know there is some rumbling about the fitment of these kits purchased thru the vendors. Some vendors, the kit manufacturer is unknown as the 3 braided lines arrive in an unmarked plastic bag. Hoses have no identifiable markings. The end result is the hoses for the front are too short and don't permit the wheel to fully turn. For this reason, I purchased the Russell kit, part # 692100, from Summit where one reviewer noted the kit "fit like a glove" on his 87 Turbo-T.
Converting to Vacuum brakes: check out the dual diaphragm booster vs. the single diaphragm. PLUS the topic search results here.
Converting to Hydroboost: two interesting options below:
http://www.cedarcrestspeedlab.com/converting-to-hydroboost-brakes-turbo-regal/
https://www.kirbanperformance.com/product/44195/CPB+HYDRO+BOOST+CONVERSION+KIT+#7619.html
Wastegate solenoid:
Brakes:
