That's some really nice offerings from
@TurboTGuy and
@earlbrown.
What
@Pronto is referring to in post #36 wrt the fan delay relay is:
The fan delay relay is not a sealed relay, so it can be adversely affected by constant exposure to moisture/water. A new relay, as shown in the RockAuto link above, has the terminals coated in bulb grease/dielectric grease for a reason. The 3 relays on the driver's side did not have a GM factory covering like the MAP sensor, A/C compressor relay, fuel pump relay and Electronic Spark Control (ESC) module did on the passenger side. So if the car is left outside in the elements, gets soaked from precipitation and driving in it and you wash the engine bay with a garden hose, over time that relay's internals will fail due to moisture. A failure sign is that your battery is dead because the internally corroded fan delay relay turned on the radiator fan and that fan operated unnoticed until the battery was drained. Kirban's listing for the fan delay relay, part # 7310
here has pics of that water damage over time.
If you keep the car out of the elements and periodically apply new bulb grease there should be no problems with a new relay. In addition, Kirban's made a relay cover for the driver's side - part #6684
here - a nice piece for $20 to mirror the passenger side.
Here is the info on radiator hoses and the heater hoses:
Coolant hoses:
Last year I did an extensive project noting the fitment problems with the aftermarket radiator hoses and lack of choices. The lower radiator hose is not the same for the 84-85 hot air engines and the 86-87 intercooled engines. And the upper hose has fitment issues with some brands. The real problem is that the correct hoses are made, however the manufacturers make it nearly impossible to find the correct hose as their e-catalogs were so lacking. not to detract from the OP's thread, but for additional knowledge, completeness and transparency to my conclusions, that thread can be read
here.
Now we all know that Dayco is the only company that makes a correct upper AND lower radiator hose for the 86-87 TB's.
Upper radiator hose = Dayco 71755
Lower = Dayco 71756
Waterpump bypass hose or "S" hose = Gates 19598. When searched by year, make, model, engine, this hose is listed ONLY for the non-turbo 3.8 V6. Dayco does not make an alternate. tired of vendors listing this Gates hose as something that they specifically had made and sell it for $25+ when it is just a $6 hose made by Gates.
Heater hoses:
Waterpump to pipe 1 (3/4 inch hardpipe from heater core) = Gates 19603. Shape is correct, have to cut off a little from the ends.
Heater core outlet to pipe 1 = Gates 28474 OR Dayco 80411. Both are cut to fit.
Pipe 2 (5/8 inch hardpipe from manifold) to heater valve = Gates 28466 OR Dayco 80400. Both are cut to fit.
Heater valve to heater core inlet = Gates 28466 OR Dayco 80400. Both are cut to fit.
For these heater hoses, I am favorable to Gates. The spec is slightly higher temp than the Dayco and Dayco only makes some of the hoses. So I'd prefer to keep all these heater hoses Gates like the "S" hose. There are some Continental heater hoses that will work as well. Check out the Rock Auto page listing
here. Again, I like the pics and part # cross references when I'm researching stuff. All the small hoses totaled $35 in mid-2017. you can pick up the radiator hoses locally at brick and mortar parts stores. Advance can't get Gates hoses so RockAuto was my solution for them.
