What are the must have casper's products please?
JimP
I want to order the ignition module hotwire kit, what are the other must have casper's products for a Turbo buick, mine is an 87 GN. I already have the fuel pump hotwired and I'm running ATR's double pumpers presently. I figure since I'm going to order might as well see what else would be nice to have.
Thanks!
I like the audible knock detector, good time to check all your electrical connections for busted tabs, etc.
In addition to what the other two posters have said, I recommend from Caspers, one of their fuel psi gauges with flexi hose and T fitting, as well as a field fix harness.
I would buy the headlight brightener, the bigger battery/alternator wire, the ground kit, the audible knock detector, the fusible link relocation kit and the volt idiot light bypass kit. John makes some really really nice stuff.
I would put the volt idiot light bypass as a must have.
Agree with GNICETRY... the volt idiot light bypass as a must have for every TR!
what does it do? I don't see it on his web site.
What he is talking about is what is also known as the field fix harness, as I posted. The field fix harness plugs in between the boost solenoid plug and the alternator pigtail. It's job is to keep the alternator charging the battery in the event the "volts" idiot light comes loose, which in turn will cause the alternator to quit charging.
