ttypewhite
- Oct 1, 2001
The key word is "THAT" sensitive. Of course every engine is cam sensitive to a certain degree. Once your into performance cams in these engine the differences are minimal. Forced induction low reving engines don't require massive cams.. Proof is in the pudding. I ran 139.93mph with unported gn1's. non stroker in a 3600lb car with a little 210/210. If you plan on a combination street/strip car thier is no need for anything MUCH bigger just a rougher idle and more stress on the valvetrain.
So true, cams do not make night and day differences in these motors. If small hyd rollers can take guys into mid 9 sec ets, the only thing above that is a solid roller, and reving the piss outta it to extract every inch of power out of it. I would not loose sleep over a cam selection. I have tried tons of cams over the years with different combonations and the difference is not huge. The key is lots of tunning along with a great tranny/converter selection to put the power down with the least amount of slippage. Imagine how much faster Birds car would run if he weighed in at TSM weight with a little more boost.
