Dec 5, 2003 #1 D DorianL Member Joined Jun 7, 2002 Messages 231 I'd guess some of it could be the stock PR. (The srping I pulled out of the pump looked pretty weak) Is it usually from worn bearings and rubber ? MTIA, D.
Dec 5, 2003 #2 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 There are a hundred things that could cause low pressure. Among them are: weak PR spring, as you stated small TV boost valve leaking TV boost valve assembly bad sealing rings and/or lip seals warped pump castings sticking pump slide bad filter seal weak TV plunger spring in the valve body malfunctioning TV limit valve in the valve body cross leaking valve body gaskets
