The "one more turn" is not allowing the puck to open far enough to waste the boost required for keeping it where you have it set. Set the rod for about a 1/8-1/4 inch stretch to the clipped pin end, then adjust boost with the chip. Or, someone can tell you how to use an adjustable valve for control. (In place of the factory wastegate solenoid.)
