SignUp Now!He sure does,but take note that he did not recommend that you add the ZDDP to your inadequate oil. Buy oil that already has an adequate amount. Every part inside your engine is subject to higher and higher amounts of pressure as power goes up. You must use stronger and stronger oil to push back against those pressures.Nick, just to be clear you recommend ZDDP even with a roller? Thanks.
