OneLethal87GN
R.I.P. Lethal GN
- May 26, 2001
When I floor it, and the car has to shift from first to second, it will hit the rev limiter and kind of hang there until I either let off the gas or it finally engages the second gear band by itself. When it does engage the band it slips. It is a newly rebuilt tranny with an Alto red band. It has a shift kit but doesn't shift hard enough to tell. I believe there is problems with the way they installed the kit. They tried adjusting the cable for it to shift harder but then I would have to get the rpms past 4,000 under light throttle and let off for it to shift gears. What causes the tranny not to want to shift to the next gear under WOT? This is mainly on the 1-2 shift.
