What Chip To Use???
marred4life
Banned
I HAVE A EXTREME EXTENDER CHIP FOR 55LBS INJECTORS, WOULD THIS CHIP WORK WELL WITH THE RAZOR ALKY KIT???? IF IT MATTERS I ALSO HAVE THE TRANSLATOR INSTALLED :redface:
May work as it is adjustable, and you can lean out the car using the translator. Bout the only thing you may need is a hot wire kit for the translator if you experience compressor surging in the 8-10 PSI range.
