what chip?
tracy
I have what seems to be a too rich at low speed condition. Causes hesitation on tip in throttle response.
I have a generic chip in it now and have read that this is most likely a chip problem. Everything else is great.
Here's the combo - can someone reccomend a chip.
Stock turbo & intercooler.
42lb injectors
70mm Accufab TB
test pipe
aftermarket fuel pump/adj reg
running 100 octane
want 20 psi boost
Who's the best chip out there??
For a stock MAF car, Eric Marshall. eric@turbotweak.com
Your tip in stumble is common with 009's. Not all vendors have this figured out. Not an issue with Eric's chip.
Check out the Commander chip at full throttle speed. Stock MAF compatible and has a ton of user adjustable features.
009 stumble is NOT an issue with the Commander or Extender chips.
Bob
Bob
Bob has the the tip in under control as well... I forgot bout the Commander. I always keep thinking Extender.. my bad, sorry.
