Apr 28, 2014 #1 P PaulRV6 Active Member Joined May 25, 2001 Messages 1,677 I have a 2004R and want to know what size boost valve is in it, what dia. will tell me this? Thanks paul
Apr 28, 2014 #2 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 A stock boost valve in a BRF trans is .471 in. diameter. Typical aftermarket larger valves are .500 in. diameter
Apr 28, 2014 #3 P PaulRV6 Active Member Joined May 25, 2001 Messages 1,677 Ok, but is that .471 or .5" OD at the two lands of the sleeve? Thanks
Apr 28, 2014 #4 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 The main TV Boost Valve only has one diameter dimension; same on both lands. The Low Reverse Boost valve has two diameters. The larger end being the part that normally varies.
