what did i break??
pacecarta
LOGGED OUT
Staff member
im sure im not the first but really couldnt find an answer using the search feature
first run this morning on street tires (235) was a 2.006 60' with 13.3 @ 100 , (02s dropped to 746 so i let out early ) on TT street chip with no lockup
2nd run switched in Turbo tweak strip chip, heated the tires a little , launched under about 6lbs boost and shortly after leaving my audible knock sensor beeped (normally i get zero kr so i dont watch the kr on the scan master at launch which is why i put in the audible for safety ), so i let off but went to get back on and had nothing , something let go in the trans , I basically rolled to the end of the track with very little forward drive coming from trans .
engine revs freely in and out of gear and is not rattling around but ive got major slippage and can only manage a little forward motion in all gears and same for reverse ,
checked all linkage and all looks good even tried readjusting TV cable but that had no effect , its as if iIm in nuetral but it will move with enough rpm , only other time i felt this was in a trans with really low fluid but my fluid level was ok and doesnt smell burnt
any thoughts??
TIA
