what do i need to run an -6 lines?
austinibew145
trying to install tyranny cooler and need to know what size fittings to use. running a 200r4?
1/4" NPST to AN-6 fittings.
they are NOT pipe thread, no taper, if you use the pipe thread fittings you risk breaking the case.
ATI makes the fittings, I keep them in stock and most performance builders probably do as well.
the line is a 6/16 the fitting is called 1/4 npt. I picked up a bunch of crap I didn't need. what a pain in the #$$. I ended up running steel lines I may post pic sometime.
It is NOT 1/4 NPT. It takes a special fitting that is NPSM (National Pipe Straight Male)
