What do think
rb84gn
I have a 1987 GN that has small mods done to it I'm thinking about racing it this upcoming year and was wondering about my ET timehope you can help.
1)walbro 340 fuel pump& hot wired
2)Fuel reg from Kirban
3)30lbs injectors
4) New dog house
5)new hooker daul exhaust21/2 with test pipe
6)3"DP
7) a fast chip
8)a good tranny cooler
9)All stuff from spring cleaning on gnttype.org
all the gauges and a scanmaster but no tach yet soon
a good pair of nitto 275/50/15 drag radeals.
I just wanna be in the high to mid 12 and a good mix of xyele fuel.
i know if you had slicks on it, you have the upgrades to get that into the high 12s or even the high 11s depending if you used racegas-
i do know alot of going fast all the time takes the right chip to make it all happen, you listed a fast chip, but that doesnt mean squat to me!
does the car have a cat on it still?
BW
no it dose not still have the cat on it has test pipe.
As for the fast chip thats the name of the chip dont know crap about it it came in the car when I bought it.
Basically you have a chip and exhaust. This alone might pick you up 2-10ths and may put you in the 13's if you hook. If you can turn the boost up (adjustable wastegate not mentioned in mods) you can prolly pick up another 4 to 8 tenths and maybe hit a 12. Alot depends on how much your car weighs and how well you hook. It would be alot easier if you have a GOOD race chip burned. All your other mods don't make you faster, just allow you to run faster more safely. Cut and paste my webpage for more detailed info. Sounds like you have all the basics done and now its time for good go fast mods.
I'll give it low 13's the way it sits assuming some traction and high 12's with some tuning and seat time. The basics are there assuming a descent chip and adj wastegate it should run pretty good. Work with what you have and get that running good before you dump thousands into it to get where you should be with what you have.
