SignUp Now!Originally posted by STP
FWIW I'm running a tapered Ross pin....
Originally posted by postal
Thanks for the input so far. The reason I'm confused is that I talked to two different reps at Diamond and they both recommended different pins. When the "experts" don't agree then the newbe's like me get confused. I need some one to tell me what pins to order for a max of 1000 hp and I'll order them. The tappered wall pins sound good but they tapper from what, X to Y? Whats X and whats Y? just saying they are tappered doesn't help me much.
Could some one please be a little more specific with the pin info. It would really help me out alot. I've never tried to make as high as 1000 HP before, and much less do it with a V6! The general concept stuff I have down. Its the little details like this where I'm lost and need some help.
TIA: Jason
Originally posted by 65vette396
Jason, I will try to help you although I do not have the exact numbers you are asking for. Possibly Ross or JE's website would have that information, but I'll try my best to help you. Tapered pins go from a large inside diameter to a small inside diameter starting at each end. Meaning you have basically a little bit thinner pin where the wrist pin sits in the piston and a much thicker pin where the rod rides on the wrist pin. This gives you the best of both worlds. You get a much, much stronger pin for a minor gain in pin weight. The way this works is simple. You have the light portion of the pin with two (2) stressed area's and thus you don't have to have near the strength in these areas (don't get me wrong, they are still more than sufficient in the strength department). And then you have the heavy portion of the pin in the main stressed area (1) point where the rod conects to the piston. As has been stated above several times the tool steel tapered pins are the only way to go. I have a set in a 985 RWHP turbo Supra with no problems as well as a set in a 1400 rwhp Turboed Big block chevy. Just call up Ross or JE and tell them what O.D. pin you need and that you want a tapered tool steel pin for that application and you will be fine. Good luck, Drew
Originally posted by EightSecV6
When we order pins from Ross, we ask for tapered tool steel pins, they handle the rest.
