Lil Truck
I spend to much time here....
- Sep 26, 2002
Never said it was not capable of 11's but traction and slippage is expected at this point. When will we see the results?
SignUp Now!Lil Truck said:Never said it was not capable of 11's but traction and slippage is expected at this point. When will we see the results?![]()
Nice I'm glad to hear that 11s is all I want for the street as its my dd car. Yeah I would like to upgrade to a FMIC soon and have my trannys built but short on funds ATM but ill get there. Thanks Dave appreciate it!
HouTX87 said:I think a fmic would be overkill for an 11 sec combo and just make your car run hotter. Get a dutt neck or a stretch slic. Just my opinion. Spend the money on a nice alradco radiator and fans. Quite possibly my favorite upgrade. I love seeing the temp gauge sit at 170 even on the hottest day.
Nice Yeah I have the gn1performance all aluminum radiator with spal fans already yeah mine sits at about 170 too on really hot days!
we4Mateo said:It'll take more than 22psi to get the hp needed with stock heads etc. Look at 25-28 probably if you want well into the 11s. Although I'm hoping to 60' my way to a high 11 this sunday on just 20psi on my te44, but I have a cam and some minor intake port matching (which really helps). Go alky! LOL, jk. Front mounts are great but not needed with a good alky tune. And alky may not be needed with a front mount, depending on your goals. I like 30psi too much to only have a front mount. I do run a CAS V4 btw.
I do have stock radials but the back is a 245 and front 215 so with drag radials should help out being I think the stock size for the back was 215 and ill run a 245 well see
HouTX87 said:You're going to run a 245 drag radial?
HouTX87 said:What size wheel? Yes you can go bigger, at least 255 is more common.
HouTX87 said:I'm running bfg drag radials 255/50-16, they're really good on the street but MT's would be much better at the track from what I've read.
Just the stock 15s if they make that and if 255 will fit with no issue ill do that
