- Mar 1, 2013
Ok, I have a 87 GN that is mostly stock except the suspension. I'll start the list of what I have, and another of what I plan to buy. If y'all can fill in the gaps or know of any changes I should make, I would like to hear your input. I have a ported intake with block off plate, precision 65mm dog house, accufab polished 65mm TB, RJC power plate, LS-1 MAF with 3 1/2" plumbing and translator, TE-44 Bison built turbo, TPS-TEC, scanmaster 2.1, AEM fail safe, knock gauge, audible knock thingy, VDO trans temp and trans pressure gauges with console pod, moser girdle, UMI drive shaft loop. That's all I can think of off the top of my head. I am looking to get 60# injectors and a TT chip, Walbro 340 pump with hot wire kit, RJC 3" DP, comp cams 980 valve springs, accufab Adjustable fuel pressure regulator, PTC 10" 2800 LU converter, razors alky kit. And possible a new timing chain as I do not know if it was ever changed. My goal is to have the ability to run 11's. I think I'm off to a good start but could use a little guidance. Also planning to have bison rebuild my tranny during the less than desirable season if he has the time so it will hold up to all this. It's not a track car, street only. May see the track once in a blue moon. And I want to somewhat retail the stock look to the car. No FMIC's. I am hoping to find a precision extended SLIC used at some point. Any impute or debates are appreciated.
