What Fan To Use
Ramchargers dual fan setup. It's plug & play and under $100. Probably the best fan deal for any car anywhere.
RAMCHARGERS...car runs @ 170* all day now took about 15-20 mins to install. you can feel the air being sucked past your hand in front of the radiator.
:eek:
smokin'6 said:
Stocker works great , or Ram Chargers dual fan is a good aftermarket choice.
Agreed, however the stocker works good assuming it's still performing to original specs after 20 years. Mine "appeared" to be running strong, but the temps still crept up to >210 in stop-and-go traffic with AC on and a new aluminum radiator. I intalled the RC dual without a hotwire and my temp now peaks at 185 in like conditions - > 95 official reported outside temps and midday stop-and-go.
Can't beat the Ramchargers for value. However, if you need the ultimate in airflow for a really tough cooling problem, the Lincoln Mark VIII is the one to beat. Flows over 4500 cfm, but requires 100 amps on startup and 35 amps continous. You'll have to trim the shroud to fit. A way around the massive current draw at startup is the progressive fan controller; it varies the fan speed according to temperature. Rockauto.com has them for $150.
if i buy the ramchargers fan without the harness will it have a positive and negative wire coming out the bottom? so i could just splice it in where the one is now? because how my fan is now there is just a positive and a negative coming off of it and i hook it up to the power and ground and there ya go..
Ramchargers Dual Fan
Thanks For All The Help And Suggestions!going With The Ramchargers Dual Fan Setup Part#674001+gn Adaptor Harness Kit
Part##674002.would I Need Anything Else For The Install?
Again Thank You
