What gauge should I add
jpratt
I just got in a T Top gauge pod to use for my EGT's. I already have the knock gauge, boost, oil pressure, and water temp as well as the SM. I have one empty hole left. Should I add a trans temp, voltmeter, or what. I plan on getting a computer later for logging runs.
Jeff
I have an electronic FP gauge in there, questionable about the accuracy of said gauge, but i mainly watch for increase when under boost.
fp
Get a fuel pressure gauge. At full boost you want fuel to be there.
I've got autometer cobalt full sweep electric gauge, used to have mechanical hood mount(hated it), electric gauge just as accurate in this case and easier to read.
If you get an electric fp guage, Autometer is the only way to go for accurrate electric fp gauge. I've had several different ones, either they break or are completely inaccurrate...Autometer got it right...its worth the extra $$. Average fp gauge is about $50-$75...the Autometer one is about $175 from what I remember.
I've the the same gauges you have with the addition of the fp and trans temp...always want to make sure the trans is cooled down each time before racing, try to keep it below 175dF
