83turbomon
Starvin Like Marvin...
- Aug 9, 2009
I heard some rumors about them on a poll, what happened to em???
SignUp Now!They've just been posted about in the HA section kid. Waiting on results from Jay, Shane, And the owner of the car.
hmmmmmkay.... I down for a set. I Hope to get this 4.1 if I dont get it im gonna get this gn motor and go BT on it.
so what does HA headers have to do with it?
you need IC headers for BT.
LMAO
A.j.
I know, I was willing to stick with the DT setup if they ever released them.
for D/T you dont need more than the stockers man.... it takes alot of motor to get ahead of even the stocker HA manifolds.
A.j.
And thats where you come in at Aj
Lol.......
i guess you gotta point...
just got to get one motor to hold...
one to hold
one to hold!
A.j.
A.j. you must just prefer agressive tuning/ ignition timing. Or your. Job has been infiltrating your garage ethics with "let's blow stuff up". Haha but I am with you on that note I've blown up plenty of Honda D series engines in the pursuit of fun.
lol.... yea im very very aggressive.
the problem hasnt really been the tune, more getting the heat out of the charge..
I have been pushing 28-30 lbs of boost.... and at that level the dischage temps are way up in the 300s. Thus, my attempt to use the meth like Donnie. I think with the injector, I can get 35lbs of boost and Live on a D/T motor.
A.j.
A.j.
how are you able to run that much boost.
35 PSI? Seriously Aj? I have a feeling your next engine will be a spectacular suprise or a really big boom.:biggrin:
LMAO
Well, Donnie and Brian have both run 35psi in the past and thats literally what it takes to make that 6-700 horsepower on a fairly stock 3.8. if they can do it..............so can I.
I have to fight that heat though... its rediculous... I think the alky being injected at that volume of flow needed to make that much power, should have a substancial effect on that charge temp. if I can cut the heat by half....... I will make my 600hp.
A.j.
If you can do an initial shot of N2O to get it spooled and then cut it down quite a bid this should keep the engine mixture cooler. This may be the way to go Aj. Just a slight mix instead of a full blown shot. Either that or the nitrogen cooller we'd talked about.
oh charlie... i think were onto something here...
raw chemical power vs. intercooler, sfi, etc etc....
it search of power... simpler might be better.
A.j.
i wish i could see his setup then i would know more.He's not using a stock intake Matt. It's an open plenum pretty much.:biggrin:
i have been using as i advance down the track/street i dont use it on the street or track much... i think i just have it there for looks most of the time. soon i am hoping to do my 301 unit... if i still have no bottom end power after the 301 turbo; i might just switch over to the 86/87 setup i already have all the parts... :frown:
