ok i guess i need to get a delay timer... i have been working with mike as well as charlie. charlie a while back, but do you have any ideas why my car has no bottom end power Aj. i have great mid to top end power but no bottom end i cant even spin the tires. i have a 3.42 gear out back and still cant spin them. i have no and i mean no power out of the hole. a while back i was having issues with spooling up the turbo and still do at one point the little flapper on top the the wastegate that moves wouldnt move but it was just a bolt that was too long. now i cant get the turbo to spool up and when i give it full gas while i am holding the break it dies out and i have to keep cranking it.. i think it because I'm flooding the thing but i havent done anything different to the carb. any ideas i keep getting told that my timing is acting like it is retarded but i know i have had it at 15,17 and 22 advance and still no bottom end power. i have it at 17 like mike told me and it made no difference. the only thing he told me to do was put a holley on but i still need to find a holley that works. i have a few holley carb laying around but mike said that the model 1850 would not work for me.. so i am on the hunt for that. do you really think that a holley carb would help or is it something bigger. here is what me and charlie came up with if you want to see the thread.heres how I use n2o for spool.
pull to the line, lock line locks, purge n2o lines, arm n2o system, depending on track conditions- set the delay timer.
begin to stage, hit beams and lock trans brake, arm timer.
at this point, I floor it.... i get about 1lb of boost at the line.
so soon as light begins to change, i release trans lock, this activates the timer for the n2o. at exactly .006 into the launch the n2o activates and pumps a 75 shot down its throat.... which makes that turbo spool.
well the 301 unit, shouldnt have such a hard time spooling, if your doing Charlies mod, if your trying to use a stock 301 unit... expect alot of lag.
to use the n2o for spool you need to use it when the engine needs it most, not when your already rolling like a ricer does. needs to be just mili-seconds after you launch..
A.j.
your the only person i have not worked with yet. i really have been just dealing with it but now i think i need more help. anyone else can chime in i need suggestions of things to do nothing has been working for me.
http://www.turbobuick.com/forums/general-turbo-buick-tech/297845-need-help.html
