What if... band anchor pin? please help
PaulRV6
On reasssembly I notice that the 300M anchor pin is not square in the bore (stock one same way) which causes the pin to extend beyond the valve body surface only on one side. Its like on a slight angle if you can picture it.
Does this cause a problem? I can push it in slightly against the band to cause it to go below surface but in free state it is above.
Is there something that pushes this pin down or hold it below the valve body surface?
I hope this makes sense in what I am trying to get an answer on. Thanks
paul
the plate will hold it just fine as long as you can push it below by hand. no worrie's
Anchor pin
Mine did the same thing, I was worried the bore was bad at first myself. When you bolt the VB up the plate should push it up in there. I've had no probs so far with that.
Thanks guys, I'm glad to hear that. It makes me feel better that I'm not the only one that had this type of concern and also that my explanation was understandable. This is always helpful information. Thank you.
paul
