Red Regal T
Senior Member
- May 24, 2001
Window shopping wheels and was wondering what kind of backspace would a 17 X 8 wheel have if they list the offset as 0 mm? tia
SignUp Now!Not True! Backspacing is measured from the outermost lip of the wheel. Typically an 8" wheel is ~9" wide overall lip to lip making the backspacing ~4.5" for zero offset as mentioned above.Backspacing is not measured using the back edge of the wheel to the mounting flange. You lay something inside the bead and measure from the mounting flange to that.
Originally posted by Mrhotwheels
Are they wrong here too?
www.thebensons.org/blkntan/backspacing.htm
Pay close attention to what you posted here about thebenson.org pic! If you notice carefully, the arrow points to the outer most portion of the lip....so yes, this pic is correct, just like I already stated!Are they wrong here too?
I guess that the top of the bead area would be flush with the back of the wheel. We would both use two different techniques to get the same results.
